Hello,
I have a .avi xvid video file, its meant to be 16:9.
When I play the file, it plays at its default aspect ratio but it seems to be squashed slightly, so that the people look thinner than they should be. If I then go into my media player and force 16:9 the aspect ratio looks correct because the people dont look thin, they look normal.
I have looked in a video program and it tells me the .avi is 624x352, is this correct for 16:9? or has the file been encoded incorrectly?
(by the way, my monitor is 16:10, maybe that is the problem?)
Results 1 to 9 of 9
Hi, contador. According to my calculator, 16/9=1.7777777777777777777777777777778, while 624/352=1.7727272727272727272727272727273, so yeah, it's a bit off. However, while forcing the correct aspect ratio in the player is a bother, reencoding is a bigger one. Sounds like you've got it handled
Best,
Calidore -
You can always use Mpeg4Modifier to for force the pixel aspect ratio or display aspect ratio. Then be sure your player is set to maintain the aspect ratio, not stretch to fill the screen.
I agree. I suspect the 624x352 is exactly how it's supposed to be, and if people appear to be too thin you've got the player set up wrong.
Or the file was encoded that way.
Thanks guys,
I've tried to adjust default AR of media player and video card driver, but the only thing that seems to work is to force media player to 16:9 -
Go on, give us a clue, what media player? external or on computer?
The electronic components of the power part adopted a lot of Rubycons.
Wrong aspect ratio on TV: could 'Autoformat' cause it?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2010, 01:34 -
Wrong Aspect Ratio
By weathervane in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2010, 22:18 -
youtube aspect ratio wrong
By Perdu in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2010, 19:51 -
Fixing wrong aspect ratio.
By mattstan in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 14:17 -
wrong aspect ratio ???
By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 02:49
