is there a limitation on the media player with the LG 47LD690 47" it wont seem to play a full hd movie file it just stops playing about half way through thank you
	Depends always on the REAL codec, size, res and bitrates used. *** Now that you have read me, do some other things. ***
	Many people, especially for some reason I can't figure out you UK people, are just completely obsessed with using your HDTVs as playback devices. As guns1inger points out, there are no guarantees. TVs are much more restrictive about what they will support than dedicated media players or even DVD or BluRay players. For example, I don't think any TVs support DTS playback at this time. It could be a size issue with the file. It could be a bad spot in the video that just makes the decoder fall over and die. If you want something that RELIABLY plays various files you download, an HDTV is not your solution. If you want the convenience of not having to buy another device, that is your choice, but then you have to just accept that some or maybe many downloaded files won't play correctly or at all on an HDTV.
 If you really must play this file on your TV, you could always try re-encoding it to a smaller size with Divx or Xvid.
  how to rip DVD to usb drive?By alexferdman in forum DVD RippingReplies: 11Last Post: 25th Jun 2011, 19:02
  Playing 720 movies from Hard drive to tv with usb help!By Cupid Stunt in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2011, 01:25
  Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03
  Samsung P-390 USB driveBy morritz in forum Newbie / General discussionsReplies: 1Last Post: 13th Mar 2010, 07:15
  Using 500GB usb drive as player on Standalone with USBBy OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 06:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			![[_chef_]'s Avatar](customavatars/avatar30571_1.gif)
