Trying a DV capture from sony HDR-HC9E to AVI thru virtualdub Using a RTX 100 Matrox capture card I recieve the following error when selecting any device:
An out-of-bounds memory access (access violation) occurred at 00b2a8ed...
...writing address 00000000.
Have attached crash info
Thanks in advance
Results 1 to 11 of 11
http://www.kiva.org/about -
I am using a firewire, however it only works through a capture card. The reason I am using virtual dub is so
I can capture without audio.
Can this be done in Windv? -
I don't care about HD cause I'm burning to DVD so it doesn't matter, and the camera is set to SD output
Windows does not recognize the camera when it's pluged in to a normal firewire slot.
might be because the cam is in HDV out mode. try putting one of the DVavi tapes in, play it until there's a picture and press pause. then plug the cam in and windows should find it as a DV device instead of HDV.
It isn't in HDV mode, it doesn't detect it anyway. It does detect it as a DV device through firewire through the capture card
A capture card adds no value. Firewire is the cleanest capture.
sony Vpro 10 "video longer than sound" sony hdr-cx116e, part II
By cesarin in forum EditingReplies: 16Last Post: 11th Oct 2011, 07:20 -
Using Sony HDR-FX1 to Capture a Mini-DV @ 24 FPS
By foochuck in forum Capturing and VCRReplies: 3Last Post: 11th May 2011, 18:50 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Sony HDR-HC3 HDV Capture
By plugh in forum Capturing and VCRReplies: 8Last Post: 10th Aug 2009, 00:15 -
Best util to capture HDVIi from Sony HDR-HC1?
By Raycaster in forum DVB / IPTVReplies: 4Last Post: 11th Feb 2008, 15:33
