Hey everyone,
I am currently having a problem with the audio on my computer and I hope this is the correct sub-forum to use.
The issue is that when the balance between the left and right speaker is centered there is an echo type effect, which means to hear audio properly I need to put the sound either more towards the left or right speaker. Its been like this for a while but it is starting to bug me now as some songs don't sound right, as some parts (say guitar etc.) in some songs might only go through one side and if the sound is centered then I am not getting the sound as its supposed to be.
Any help with this issue would be appreciated
Thread moved to computer forum,sounds like your center speaker isnt working or you got a 5.1 system thats set to 2.0 stereo,check in the control panel/audio and test the configuration to see if all the speakers are working.
Audio out of sync, how to determine delay needed.
By mattstan in forum Authoring (DVD)Replies: 9Last Post: 23rd Dec 2019, 02:26 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Audio Effect help needed (Pinnacle Studio 11)
By JohnP in forum EditingReplies: 0Last Post: 5th Apr 2011, 04:44 -
Audio Encoding Help needed for VirualDub
By Qasim in forum AudioReplies: 8Last Post: 30th Apr 2010, 08:02 -
Audio analysis software needed
By Nelson37 in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2007, 23:17
