Hi. I've been using MPC-HC for a few months now and I really like it. Unfortunately, there are a few files that it just refuses to play. avis, mpgs, flvs, big files, small files. It seems totally random. What makes it even more annoying is that the same file will then play perfectly in VLC. But I don't like VLC. It's got an ugly interface and the install takes up too much space on my netbook (about 70megs on only a 16gig SSD). So how do I make MPC-HC play the files that VLC can play. I'm pretty competent with computers, but I'm after a solution that's quite straightforward. I don't want to spend 30 minutes fiddling around with the settings just to watch a film, y'know?
Try changing the DirectShow Video renderer in settings.
Pull! Bang! Darn! -
What should I change it to? Is there one that's more compatible than the others?
Depends on your graphics card and drivers. But problems with the output device usually show up as no picture, lockups, or crashes.
I would look at what filters are enabled and disabled. View -> Options -> Internal Filters. Source Filters and Transform Filters. When you find a file that doesn't play use MediaInfo to see what codecs are used and what the container is. Make sure the Source Filter for that container is enabled and the audio and video codecs are enabled in the Transform Filters box. -
What jagabo said.
Anyway, last time I did a fresh install I experienced your problem, and the answer was as simple as changing the renderer from System Default to Overlay. Worth a try.Pull! Bang! Darn!
Lagarith and MJPeg Videos not playing in MPC but OK in Virtualdub ?
By blewyn in forum Software PlayingReplies: 5Last Post: 18th Jul 2011, 03:40 -
MPC HC x64 double images/videos since svn 1503? (pix attached)
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2010, 08:30 -
weird problem with mpc while playing videos
By CheekyKid in forum Software PlayingReplies: 3Last Post: 23rd May 2009, 07:38 -
Problems with ffdshow, MPC and .mov videos
By ziptip in forum Newbie / General discussionsReplies: 1Last Post: 26th Dec 2008, 05:14 -
MPC software for playing DivX videos on Win2k
By Fredw in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Jun 2007, 16:14
