Hi Everybody.
I want to make a PAL DVD from my MPEG-4 videos. What is the best way to get a good quality PAL video from a MPEG-4 video.
I am pretty new at this conversion subject. I have ProCoder3, but all my efforts ended up with low qualityPAL video. Am I using the wrong settings? Should I use another method?
Thank you.
PS: Here is the detailed info about the MPEG-4 file I have.
General
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 36.5 MiB
Duration : 34s 34ms
Overall bit rate : 8 989 Kbps
Encoded date : UTC 2010-02-06 13:27:27
Tagged date : UTC 2010-02-06 13:28:02
Video
Format : MPEG-4 Visual
Format profile : Advanced Coding Efficiency@L4
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 34s 34ms
Bit rate mode : Variable
Bit rate : 9 000 Kbps
Maximum bit rate : 14.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.326
Stream size : 36.2 MiB (99%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : Yes
Codec ID : 40
Duration : 34s 5ms
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 266 KiB (1%)
Results 1 to 9 of 9
are you sure you need a PAL dvd ? Most PAL spec players play NTSC material
Assuming your material really is 29.97p , there is no "nice" way of converting 29.97p => 25p . You drop frames because a simple slowdown is too large and noticeable. This is choppy.
For film material 23.976p => 25p , you can do a simple speedup (incl. audio) , because the difference is smaller. This is what is normally done. This will play back smooth because no frame drops or insertionsLast edited by poisondeathray; 26th Jul 2010 at 19:33.
Well the DVD will be distributed to many people. So people will watch it on different DVD players. As far as I know not every PAL DVD player does a good job converting the video from NTSC. That is why I want to take care of that issue.
I used MediaInfo to look at the properties of my videos. They look like they are 29.97 fps. -
Yeah, but as pdf said, if the 'real' framerate is 23.976fps, it can be done properly. If it's really 29.97fps then you're always going to have missing frames (or a blurry mess). The way you can tell which you have is by advancing frame-by-frame and seeing if there's a duplicate frame in every 5. If there is, that would mean it's film-based and it can be converted to 25fps properly. Otherwise, if you insist on making a PAL DVD out of it, you're screwed.
It looks like my video is 29.97. I have checked 5 frames in Premiere Pro. None look the same. They all are advancing frames.
Somebody must have solved this problem. -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
PAL to NTSC Conversion with DD
By cottage in forum Video ConversionReplies: 5Last Post: 16th Feb 2009, 16:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
