Here's my problem. Years ago I transferred my Hi8 analog videos to DVDs by hooking up my 8mm recorder to my consumer Phillips DVDR77 player/recorder. Now I'd like to transfer the movies from these DVD's to my computer to edit them and then just store them on my computer in MPEG or MOV format or whatever. But I'm not finding it to be very simple. The format seems unrecognizable using standard Mac or PC software (I'm using a Mac but I also have a PC available, with Adobe Premier Elements). I'm thinking I probably have to capture the info in real time but even then I don't see any way using the software I've got. Any suggestions for software that would do the trick?
Thanks so much!
dvd's are just data discs. no protection if you made them yourself. there should be audio_ts and video_ts folders on the disc. the video_ts folder contains the video in the form of vobs, ifos. and bups. the easiest way to deal with them if you want an mpg is to use vob2mpg and create a single mpg video file from the dvd and write it to your harddrive. the free part of vob2mpg should be fine for the task.
and welcome to the forum!--
Authoring a home-made DVD problem
By elmuz in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2010, 07:28 -
CSS problem on home-made dvd
By rayc1234 in forum Newbie / General discussionsReplies: 37Last Post: 25th Oct 2008, 04:12 -
home made dvd to divx widescreen problem
By mark70725 in forum DVD RippingReplies: 7Last Post: 1st Oct 2007, 03:13 -
Problems copying a home-made DVD
By jj1807 in forum Authoring (DVD)Replies: 3Last Post: 2nd Jul 2007, 14:20 -
removing background noise on a home made DVD?
By Rudyard in forum AudioReplies: 2Last Post: 22nd Jun 2007, 14:29
