Hi everyone,
As I'm new on this forum (though I've been visiting it for a while) I would like to say hi and thanks for your upcoming help.
I'm currently working with ffmpeg on a mac. I'm now trying to merge an audiofile to a video.
I used this (upon 100 others) command :
ffmpeg -i output.mpg -i audio.mp3 -ab 192k -vcodec copy outau.mpg
This is working but I've too problems :
- If I navigate through the video with QT then the audio stream stop.
- I would like to add the same amount of time of audio than the video and not a complete audio file (i.e my video is 1 min and my audiofile is 4 I would like to get only the first minute of audio to match the video and don't want the complete audio).
Thanks for all your help.
Best,
Hi
This is the command that I suggest:-
Code:ffmpeg -i output.mpg -i audio.mp3 -shortest -vcodec copy -acodec copy outau.mpg
Thanks for this -shortest !
I didn't use -acodec copy because my original video file doesn't have any audio and then this command doesn't work.
It works for my second point sadly the first problem is still there : If I move on the video using the player navigator the sound stop to play.
Any ideas ?
EDIT : Someone ??Last edited by Tom2me; 27th Jul 2010 at 04:01.
Hi, I have 2 files: Audio.wav (duration 1 minute 16 seconds) and Video.mp4 (duration 1 minute)
I have to pack both of these streams in a single video (op.mp4) with the following requirement:
Video will start playing after 16 seconds only till then black frames should appear.
How can this be done using ffmpeg?
ffmpeg: getting quality loss of avi when adding audio back in
By vidgem in forum AudioReplies: 2Last Post: 15th Mar 2012, 23:39 -
.mpg -> .mp4 using ffmpeg, Video is choppy and 2x too long
By rccollins in forum Video ConversionReplies: 3Last Post: 11th Dec 2008, 10:20 -
Adding audio to end scene of mpg video
By martin01p in forum EditingReplies: 5Last Post: 10th Oct 2008, 06:04 -
FFMPEG audio/video desynchronized (converting video server side)
By Lleoun in forum Newbie / General discussionsReplies: 1Last Post: 18th Apr 2008, 07:19 -
Synchronizing audio/video with FFMPEG
By beyondthegrave in forum EditingReplies: 2Last Post: 13th Nov 2007, 08:32
