Is it possible for me to have two display inputs on a single monitor?
I have an external TV tuner card connected to the DVI port on my monitor & the CPU connected on the VGA port. Is it possible for me to have both the displays on my single monitor side-by-side or like PIP?
Acer 23" h235hbmid HD Monitor [VGA, HDMI, DVI]
Onboard Graphics - ATI Radeon 4250
Not unless the monitor has the circuitry to do this, or you have a video mixing box that can do it for you. A switching box or two monitors would be the cheaper option.
If the tuner card has software that allows you to watch the signal on your PC, use that to get PiPRead my blog here.
Dual Input LED Monitor
By blinky88 in forum ComputerReplies: 15Last Post: 28th Apr 2011, 10:23 -
direct display of captured input to monitor
By admaw11 in forum Capturing and VCRReplies: 2Last Post: 8th Jan 2011, 16:31 -
GL2 LCD Monitor Display
By HarveyCee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th May 2009, 17:32 -
Sigmatel input monitor issues
By GLE3 in forum AudioReplies: 2Last Post: 14th Mar 2009, 16:25 -
TV Tuner Display on Secondary monitor?
By wakarusensei in forum DVB / IPTVReplies: 4Last Post: 6th Dec 2008, 15:51
