Closed Thread
Results 1 to 12 of 12
    Dec 2004
    Asheville, NC
    Hello folks.
    We brought a movie DVD home from the library and got about 1/4 through when a giant scratch brought it to a screeching halt. It worked on it for a while, then started playing for a few seconds before stopping again. And again. And again...
    I was wondering if there is a decrypter or something that could get it into the computer. That way, I could put it on a DVD-RW, we could watch it, then just erase the DVD-RW. (Probably hard to believe, but I don't really feel the need to keep "Fantastic 4" for my very own!)
    Any ideas?
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    the scratch usually makes it uncopyable
    rent another for a buck?
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    First wash and dry the disc.
    Try ISOPuzzle. It read what it can and keep retrying on the hard parts. It might make a playable image even with some glitches.
    If it can't get to 100% just stop it if it seems to be not adding new data and burn the ISO (with blank bits) it makes.
    Otherwise, you can try to polish the scratch a bit (don't tell the library you did that, of course).
    Put it on a hard flat surface and polish with Brasso and a soft cloth, rinse clean with some dishwashing liquid, carefully dry.
    It will take off some of the mirror shine, but that won't affect readability that I've noticed.
    Worth a try as it's f***ed already.
    And yeah, it's pretty dumb movie, don't sweat it. Get Watchmen.
    Find a rental store that uses one of these: http://www.discchek.com/
    Most charge about $3 to fix discs for you.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by johnsees View Post
    Hello folks.
    Any ideas?
    Copying a DVD that you do not own is illegal....even if you plan on using a DVD-RW and say that you don't really feel the need to keep it.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If you feel so strongly, call the FBI. Don't waste everyone's time here with this petty finger wagging.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Copying a DVD that you do not own is illegal....period.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    And in other breaking news, comma water is wet! Exclamation mark
    Forum rules.
    Thread reported.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Forum rules.
    Thread reported.
    Twice.
  11. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Forum rules.
    Thread reported.
    There is a forum rule that requires you two self-important jerks to form a kangaroo court and lecture everyone on the evils of copyright piracy --- even though it's quite clear that even the most rabid RIAA type enforcer wouldn't waste his time on this trivial hypothetical infraction?
    Give yourself a merit badge.
    My point is that if you TRULY BELIEVE that a rule has been broken, just report it and leave a REAL moderator to decide.
    Don't make post after post trying to inflate your sense of moral superiority.
    Every person who contributed to the thread by default gets a notification every time you do this. I don't like having my time wasted by you. I doubt anyone does.
    Twice.
    Oh no, you can't let anyone else claim credit for your "collar" can you?
    Since you've both thoroughly poisoned any discussion here, I'll unsubscribe and leave you to it.
    MISSION ACCOMPLISHED!! Well done those men!
  12. Mod Neophyte redwudz's Avatar
    USA
    Fair use DOES NOT APPLY TO rentals or borrowed media or streaming tv to everyone. Thread locked.
