Hello,
I have a mpg movie that I made with a Mavica camera.
I used TMPGEnc to convert it to a VCD. (I think. I used their wizard)
I then burned it to a CD-R. I have a Pioner DV343 DVD player.
When I put the CD-R in the DVD player nothing happens.
I know that it will play VCD's. All the VCD's that I have played,
have the mpgsav (or something like that file and and inside the file
is .dat. This my DVD player will play. Is there a way to get
TMPGEnc to convert where there is an extension of .dat
Or what am I doing wrong? I have already wasted two CD-R's
trying it. Thanks, Bill
So you got a mpg video from your camera and used TPMG to convert it to the VCD standard. Then you burned it to a cd-r. When you burned it to the cd-r how did you do it? I think thats your problem. Check the "How to" section under "Author." 8)
AutoMKV - am I doing this wrong?
By Phat J in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 03:50 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Somethig Wrong!!!
By SIRCOOKS in forum ComputerReplies: 11Last Post: 7th Feb 2008, 16:03 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
