Hello,
I'm trying to add a second audio track to a mkv file.
The second track comes from an avi file which i extracted using AoA Audio Extractor. I Then used belight making sure the Sample Rate was 48000Hz and the bitrate at 192kbps which the original audio track is set at.
Then using mkvmerge i set the delay for the audio track a second back to sync up the audio and video. Then merged it.
When playing it starts perfectly then slowly goes out of sync more and more into the movie till the point where the audio is totally in a different scene then the video.
I left the delay option alone to see if that was doing it but it was not.
How do i fix this?
BTW the avi file is 23.976fps and the MKV is 25fps.
Thanks in advance
Results 1 to 11 of 11
How did you speed up the audio?
OK tried something different,
I extracted the h264 video file using mkvextract. Then using mkvmerge GUI i change the framerate under 'Format specific options' to 23.976024.
Then i merged that file with the audio file.
It is PERFECT at first, then the audio starts going faster then the video now!!
lol
Im out of ideasLast edited by sirius247; 25th Jul 2010 at 19:46.
Fixing the framerate is a start, but the real issue is simply length. You said this audio track was from a different video, so apparently the length isn't a perfect match. Get the _exact_ length of both the audio file and the video it's going on, divide, and then stretch/shrink the audio as appropriate before grafting it on.
Example: When I'm using Virtualdub to convert a 25 fps video to 23.976 fps (I _hate_ the PAL speedup effect), I use its advanced "stretch" audio filter with a ratio of 1.04271. Perfect sync, every time.
Audacity has a stretch function, but the early version I used to use only went to two decimals, which wasn't precise enough for movie-length files. I don't know if current versions are better; otherwise, I'm sure someone here can recommend an audio tool that will do it. -
Ok thanks for the help guys.
Now how would i use Audacity? I loaded my extracted ac3 audio file into it. and then Selected it all, when i go to change speed im not sure exactly what to put in?
My video file length is: 43:11 and the audio is: 43:07
I played around with the change speed but when i export it as a mp3 i ended up getting a blank file 8kb in size.
Not sure what im doing wrong
BTW. I installed Lame Encoder so this should work..
Also cant use VirtualDub as it wont read my MKV(original video) fileLast edited by sirius247; 26th Jul 2010 at 06:58.
Blu Ray slowly gets more out of sync longer you watch it... Using Leawo
By bigt85 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jan 2012, 06:05 -
A/V goes slowly out of sync when using MKVmerge
By Tyho in forum Video ConversionReplies: 3Last Post: 10th Oct 2011, 16:55 -
A/V slowly gets out of sync using RipBot
By patmann03 in forum Blu-ray RippingReplies: 3Last Post: 7th Aug 2010, 11:32 -
Audio drifting out slowly - Gradually goes OOS.
By blackflames in forum AudioReplies: 23Last Post: 10th Jun 2010, 06:02 -
Audio slowly goes out of sync with video
By wolf2009 in forum AudioReplies: 5Last Post: 3rd Nov 2007, 07:05
