I am currently using HDTV2MPEG2 to edit out commericals and then Nero Vision (From the Nero 9 Suite) to convert captured OTA HD TS video files to SD DVD. It works and is relatively easy to do but I was wondering if the Nero 9 encoder is considered to give good quality compared to say HCENC which I am use to using. I am not that concerened with speed. Can anyone give their recommendations for a better (quality wise) freeware way to go about it or comment on the Nero Vision encoder?
two suggestions:
multiavchd
avstodvd
I have used avstodvd for bluray to dvd conversions but it can take ts files. I have used multiavchd just for high def avchd output BUT it can output to standard dvd as well.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Your conversion recommendations ?
By PowerFalcon in forum Video ConversionReplies: 3Last Post: 25th Dec 2011, 19:25 -
home movie film conversion recommendations?
By spiritgumm in forum Off topicReplies: 0Last Post: 6th Nov 2010, 09:04 -
Recommendations for DVD Burner
By dqtus in forum DVD & Blu-ray WritersReplies: 9Last Post: 11th May 2009, 11:59 -
Current recommendations for Laserdisc conversion
By tonyaldr in forum Video ConversionReplies: 3Last Post: 19th Jan 2009, 09:06 -
Newbie post - Recommendations for VHS-DVD Conversion.
By Mysticle31 in forum RestorationReplies: 20Last Post: 8th Jul 2008, 00:51
