Closed Thread
Results 1 to 15 of 15
    Jul 2010
    United Sates Of America
    Hello,
    I am having trouble with adobe premiere cs5.It always crashes when trying to load "quicklooks.aex" It used to work earlier.I tried updating to 5.01 but that did not help at all it is still the same exact thing.Does anyone know what is the problem is?
    Oct 2005
    666th portal
    are those your current computer spec? if so your cpu is not supported.
    Jul 2010
    I don't see why my intel celoron 900 @ 2.20 gz would not work.The program worked before.
    Oct 2005
    666th portal
    it's not designed to run on it. why would you even try to run a high end $2000 program on a $200 computer?
    Windows
    • Intel® Core™2 Duo or AMD Phenom® II processor; 64-bit support required
    Jul 2010
    The computer was $330 not $200 also did not buy adobe premier I got it off the internet.Also After effects cs5 works just fine so I think this might not have any thing to do with my computer specs.AND the program worked before so I think it is something that might have gone wrong.
    Here it is computer spec screen-shot to prevent confusion
    I reduced it to 16 color to make it load faster.
    Oct 2005
    666th portal
    warez isn't supported here.
    Jul 2010
    I did not post how to get it for free.I did not post were to get it for free.I did not tell anyone that this is a good idea.Just to prove that I did not break any rules I have posted the Warez rules below.
    From rules:
    Warez rules
    What is warez? Obtained IP (intellectual property: software/music/movies/tv-series/tv-shows) either through download, serial, or crack in a manner that either explicitly or implied breaks the copyright or license for that IP.
    Do NOT give warez / Do NOT link to warez
    Distributing warez. This includes linking to warez either directly or to crack or serial sites. Offering warez in any fashion including PM or e-mail is against forum policy.
    Do NOT ask for warez
    Asking for warez. In any fashion this is unacceptable including but not limited to PM or e-mail requests or information on what p-2-p network has copies.
    Do NOT provide information on how to obtain warez
    Providing information on how to obtain warez.
    Do NOT advocate warez
    Advocate warez. Recommending the use of warez.
    Jul 2010
    Hate to double post but I got it working!It was a plugin that needed internet and windows firewall was blocking it.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    warez phoning home... interesting, wonder what it's sending...
    Jul 2010
    No i don't think it is that.I will run the free http sniffer to see if you are right.
    Jul 2010
    I could not get the program to run but the reason why it needed the internet was because a plug-in was checking for updates.Also this time it keeps crashing on look3.aex
  12. Premiere CS5 doesn't need to phone home to run, it doesn't matter what plugins you are using.
    Nov 2010
    Mexico
    "quicklooks.aex" Its a fliter from Magic Bullet (quicklooks) is possible that your version is not compatible with your program Premiere. Find it and delete and your program work.
  14. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    You paid $330 for a $200 computer?
  15. Mod Neophyte redwudz's Avatar
    USA
    Discussion of Warez is still a violation of our rules, call it advocating if you like. Thread closed.
