Results 1 to 11 of 11
  1. hello i need so much the help.
    there boxes how delete on video the whater in big box? or how change nubers if i cut it nubers start suffling on 9 :S put i need make 0-...
    i hope you understand me and can help me i need it really. are it possible? i have 2 programs sony vegas pro 9 and MAGIX Movie Edit Pro 16 Plus Download Version.
    sorry for posting on wrong section i don't know where i need post it
  2. I don't understand your question.
    If you delete what is in the box, you have to replace it with something. e.g. Do you want black ?
    You can air brush or use clone stamp tool in photoshop or after effects
  3. nono it is video i need make it look like pic2
  4. I still don't understand.
    Are you trying to make the "path" thinner , and change the numbers ?
    You can still use photoshop or after effects (photoshop extended can work on video) . Or you can decompress to still images, edit , then re-assemble into video . You might use masks and overlays to replace items as well
  5. i upload the video on youtube then u see and understand what i want to do
  6. or how edit the 1k-119 <-- 1k - 112
    PVC 160 mm
  7. Same answer: mask out the numbers and replace them
    It's easy to do for a static number , more difficult to do for changing numbers (because have to do multiple frames)
  8. can help on TeamWiever?
  9. Mod Neophyte redwudz's Avatar
    USA
    bmaster, I changed your title to better reflect your question, as per our rules.
    Moderator redwudz
