I recently upgraded one of my computers with a newer mobo & AMD Athlon II X2 250 cpu... The new mobo only has one ps2 port.... I tried usb to ps2 adapters on my existing ps2 KVM switch but 90% of the time the mouse or keyboard (which ever one is plugged into the adapter) will not work... I've tried a ps2 to ps2 y adapter and a ps2 to usb y adapter with no luck...
Plugging the keyboard and mouse via adapters into the computer work about 50% of the time... Plugging in a ps2 keyboard (or usb keyboard) and usb mouse directly into the computer work 100% of the time...
I have 4 computers... Presently I have two kvm ps2 switches but would like to reduce it down to one kvm 4 port usb...
Anyone recommend a good kvm with 4 usb ports...
Thanks kindly
I've been happy with Iogear. The models I use are for two computers, USB connections and VGA output. I have three of them in use at present. I like them because they are inexpensive and come with all cables. Mine use the 'Scroll Lock' key on the keyboard for switching, which is much more convienient than a cabled switch as the PCs are about 15 feet away. And mine works fine with a wireless mouse and KB. Not all KVMs do. I haven't tried one of their 4 input KVMs, but I assume they are similar. If you have DVI, they have models for that also.
http://www.iogear.com/solutions/kvm/ -
Which ever brand/model you get, make sure it lists win7 compatibility like IOgear does on some of their models
I just bought the GCS632U
*IOGEAR’s Display Emulation Technology provides the EDID support for Windows 7
LG DV382 - USB Port
By Yabuike in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Oct 2011, 08:41 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Can someone recommend a good USB style tuner device for me
By True Colors in forum Capturing and VCRReplies: 0Last Post: 31st Jan 2010, 15:12 -
Desperately Need Help Finding a Good DVD Player With a Usb Port That Has...
By thewonderer in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Apr 2009, 17:07 -
USB port on DVP
By hootal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2008, 09:35
