ok, I have a windows machine that i installed iis. I created web folders (default) and can access them over the internet. the problem is that i can't stream my movies without embedding html (which i have tried unsuccessfully). I did finally figure out i had to install a mozilla plugin to generically stream in google chrome, but no controls and very slow streaming. I tried to put a .m3u playlist file into my shared folder, created from vlc, and it will play locally but not remote (this is the method i would prefer). I assuming its because the .m3u file is pointing to local files and when a remote computer tries to access the file tries to play the video from THAT local machine, and can't.
I became so frustrated i decided to try and stream only using the vlc 1.1.1 (newest) with html interface. And once again i had no or little success.
So, what am I doing wrong here. How can I create a playlist using the vlc player (either in my website or not) for remote streaming????? thanks
Chris
Results 1 to 1 of 1
Streaming problem VLC
By suvendu4urs in forum Video Streaming DownloadingReplies: 0Last Post: 14th Oct 2011, 09:01 -
how to streaming with VLC v1.1.4 on vista
By pRincezZ_fe in forum Video Streaming DownloadingReplies: 0Last Post: 16th Dec 2010, 01:16 -
Webcam streaming with VLC
By Cazz in forum LinuxReplies: 6Last Post: 29th Jan 2010, 12:42 -
VLC html code for my web site
By nikola_mk in forum Video Streaming DownloadingReplies: 0Last Post: 21st Dec 2009, 17:39 -
Live TV streaming to Web via VLC - Total n00b, so go easy on the flames...
By br3nton3 in forum Newbie / General discussionsReplies: 9Last Post: 2nd May 2009, 16:24
