I made an avi digitized version of some content using DVDFab Platinum in the normal procedure I always use. On this item I have no sound. It is not multiple language that I recall.
To simplify, I always use "generic" for the AVI option.
What should I look for to correct for sound?
What are some program alternatives that I may have missed over time?
	Just rip with dvdfab decrypter and then convert to avi with autogk or staxrip.
	I re-examined the audio track. it is listed as "undefined" PCM/2 I guess for pulse code modulation.
 Does this effect the coding because it is not AC3?
	run media info on Source Video Contents and figure out which audio stream it contains.
 i guess, but not pretty sure as DVDShrink, DVDFab must have offered you audio track selections which one to keep, isn't it?
  Output AVI from DVDFab has doubled the videoBy alffan in forum Newbie / General discussionsReplies: 5Last Post: 1st May 2012, 02:56
  No sound from a PCM audio stream using DVDFab DVD to AVI file.By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 05:27
  How To Convert Dvd To Avi Using DvdfabBy Bonie81 in forum DVD RippingReplies: 3Last Post: 7th Apr 2010, 00:40
  How to convert MKV with soft subs to AVI using DVDFab 6.xBy Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 10:15
  DVD (VOB) to AVI Problems Using DVDFabBy BiggerJim in forum DVD RippingReplies: 2Last Post: 27th Feb 2008, 10:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
