Can anyone please tell me how to do the effect at 0.08 of the below clip?
http://www.youtube.com/watch?v=mmOE5-Z1nDo
Cheers
D
If you mean the like-leaked film effect while it's switching from the countdown to the traintracks, it looks like they are using the eyetide film clips and overlaying them. Eyetide.com seems to be down right now
Thanks for the reply frlane. Yeah, i'm after the effect where the red and orange colours are moving across the clip. I've been trying Eyetide.com all day but as you said its down. Do you know any where else i can get the eyetde clips from?
Achieve the best possible audio quality.
By Robertiebert in forum Video ConversionReplies: 8Last Post: 23rd May 2011, 10:35 -
How can I achieve a Technicolor effect in Virtualdub or Debugmode Wax?
By hbenthow in forum EditingReplies: 27Last Post: 11th Feb 2011, 12:41 -
How to achieve this special effect
By AndrewVlcek in forum EditingReplies: 2Last Post: 7th May 2009, 11:55 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
How can I achieve this "corrupt compression" effect
By tomdarra in forum Video ConversionReplies: 3Last Post: 23rd Sep 2008, 14:49
