Hey, simply put,
I want to play music (same song) from two different computers and have it sync'd. How can I do this?
I have a media center pc hooked up to my 5.1 home theater system and a desktop in another room with a nice set of logitech speakers. My computers have data drives that are mirrored, thus each has the same exact music library. I currently use iTunes on each to play the music. Is there any way to press play on one pc and have both output (or play) the same song at the same time (no echo)? Seems like i remember Winamp 2.x had this feature, but is there any more modern software that does this?
Any extra features, like volume control on both computers would be welcome!
Thanks for any help!
Even if the play at exactly the same time, unless you are in the exact centre between them there will be an echo simple because the sound will reach the listener at different times. This is why surround systems have delays built in. If the sound came out of the front and rear speakers at the same time, it would sound odd. Same with two computers.
You could try streaming from one PC using VLC, and pick up the stream on the other. You can have the first machine play as it streams, and the second PC will get the same music at the same time, give or take a few milliseconds.Read my blog here.
sounds like a good idea, maybe the only viable solution.
Thanks, guns1inger!
any one else have any ideas on this?
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 10:40 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38
