I followed the procedure posted here and it worked ok.
However, I messed when I entered the region I wanted and pressed "7" instead of "9".
How can I fix it?
I tried but there is no unlocking code for region 7. The ones informed in the procedure cover from 1 to 6.
Sometimes when you make a mistake in entering a code, there is no way to fix it.
You can always asked the guy that had the codes. he's the one that came up with those maybe he'll know. Region 7 doesn't exist so isn't it region free too??
By the way, anybody here bought this unit in region 1 player??? did you successfully unlock it? cause i've been trying since i got it yesterday and i don't know what i'm doing wrong. i saw other post but people had regopn 2 or 4 unit... so i was just wondering. let me know. -
I had similar issues but from region code 3 to 5. Keep using the sequence for your region's DVD player, change it to that original region, and from there change it to 9.
In my case: Original Region Code (RC) 3. Used remote control sequence for RC 3. It then became RC 5 for some reason. I kept using RC 3 sequence to try and change it to 9, but this did not work at all. So I then used the RC 3 sequence, it still showed RC 5 and changed it back to 3, the original setting. Then I used the RC 3 sequence again and could change it to 9.
Thus in your case it might help to keep using the sequence for your original region, let's say region 4, change the setting from region 7 back to region 4, and then again use the region 4 sequence to change it to 9. Hope this helps.
Region free code for Samsung C5500 not working on US version of players?
By whatz in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st Dec 2011, 20:31 -
Region free hack for Samsung C5500?
By letshavefun3 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2011, 23:21 -
Samsung BluRay BD-C5500
By ce6pcm in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jan 2011, 19:23 -
Samsung BD-C5500 Need Help...
By cetrax in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2010, 20:08 -
Samsung v5600 region free but picture is messed up
By daniel86 in forum Newbie / General discussionsReplies: 0Last Post: 19th May 2007, 10:53
