In the settings on the Direct Show tab everything is set to automatic but when iimport a T.S. file i get the folling warning message stating:
The current used splitter/demuxer
Mpeg Splitter
does not provide the capabilities required to selecy audio streams !
Try selecting a different splitter/demuxer filter in program setting.
But when i change it i get a message stating
Directshow problem - Falure while trying connect file source output pin to preferred splitter/demuxer filter input pin.
I havent changed it to all the options yet as all the ones iv tried so far gave me the same messaage, any ideas, thanks
ok bare with me on this, i have noticed when i play a .ts file a white icon (it looks like wings) appears on the task bar, i think this is Haali but there is no programe in 'all programes' list i did install another Haali using the link in the above post, but i dont know what im doing, how do i use it (i feel a bit stupid really) i opened Haali then open the .ts file into it clicked convert (or something similar) saved the .ts file, but when i opened this new file it was turned into a different file format that the .ts sniper would not load, to be honest iv given up on it and found a programe called videoredo plus that does all i want with a .ts file and it also does the same for .vob files and you can save the edited file in a mpeg format if you want and is really fast, it is a pay for app' but you can find ways around this if you feel inclined.
Yeah, i tested Videoredo these days. Not perfect, but with some add-on not bad for my video editing.
Itīs my No.1 atm, itīs more stable than my former programm MPEGStreamclip. -
I have exactly the same problem. After changing the splitter to Haali (AR) I dont receive the first error any more, but the second one for most of .ts files (not for all of them). It would be great if someone gave me a tip how to configure the ts-sniper or if there is an another free program to cut and merge my records (.TS), and further how to convert them into X264-mkv.
cheers,
linch -
Hi,
I have the same problem amd also haali AR don't solve my directshow peroblem...render filtergraph...
I m under 7 64bit (I tryed also in winxp mode).
Some ideas???? Other software?
And more, is possible that don't exists other "free" ts/h264 cutter? All project are beta, or older....
For ts/mp2 I use the wonderful ProjectX, why don't exist a similar software for ts/h264????? Is very strange!!!!!!
Best regards
Problems editing .VOB files
By Jose_A_Duran in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 16:44 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Cool name for new pro video editing app?
By scusa2000 in forum Off topicReplies: 10Last Post: 6th Aug 2008, 20:25 -
Which Is The Best Video Editing App ?
By blewyn in forum EditingReplies: 6Last Post: 24th Mar 2008, 19:57 -
Codec Sniper in vista
By buttzilla in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 03:33
