Has anybody had this problem and what causes it
I clean the sound (voice mono) in soundbooth, convert it to sterio and place it in the voice track of Corel video editor then burn to DVD via Nero.
The sound moves from one speaker to the other and back again for no reason, It does not seem to be moving due to bass or treble, just changes speakers in the same place when I put the DVD in any machine.![]()
If you listen to the audio from your PC, does it do the same thing ?
What is, instead of converting to stereo, you copy the mono track, create a new empty stereo track, then paste the mono track into each channel and save the new stereo track ?Read my blog here.
Thanks guns - wow that was quick
yes it does it on every type of playback.
ok I'll try doing as you say - I'll need to think about it - bit confusing
So I think you mean to do this in Soundbooth before I place it into Corel as Corel does not have 2 sterio tracks for voice -
Yes, do it in the audio editor. A convert to stereo process should take a mono track and juct copy it into both channels evenly. It sounds like Soundbooth is trying to take a mono track and create a stereo track with faux separation and panning, and is failing badly at it.
Read my blog here.
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 02:40 -
PC Speaker's as TV Speaker's
By wulf109 in forum ComputerReplies: 2Last Post: 14th Jan 2011, 18:36 -
TV Sound x Speaker sound
By joelson in forum AudioReplies: 4Last Post: 20th Sep 2008, 23:45 -
Mitsubishi announces LCD TV with integrated 16-speaker surround sound syste
By joytimeday in forum DVB / IPTVReplies: 2Last Post: 11th Jul 2008, 10:11 -
Help: Sound only plays from left speaker
By rdc in forum AudioReplies: 5Last Post: 31st Dec 2007, 22:25
