Is it possible to send video to Sony Vegas via Virtualdub frameserver? I need to apply some Avisinth scripts and VDub filters on a video in first step and put some text using Vegas features before encoding it to mpeg2.
I tried it doing the same procedure I use to encode in TMPEenc. Unfortunaly it didn't work. Vegas say that avi dummy file isn't valid...With TMPGenc always works well.
Do you know how to do it? I mean, apply scripts and filters in VDub and later put text stuff using Vegas?
Or is there another way or workaround to do that?
Cheers.
Thank you.
WAX2 works as a plugin to Vegas and allows you ro use some virtualdub filters in Vegas.
Read my blog here.
There is a version of Neat Video specifically for Vegas . . . . . . . .
Read my blog here.
In my experience, the only consistent way of frameserving IN to vegas avisynth virtual file system (AVFS) . MakeAVIS from ffdshow is 50/50 (sometimes works) . You can frameserve OUT of vegas with debugmode frameserver
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
VirtualDub to sony vegas problems HELP
By iTzRingoBrown in forum Capturing and VCRReplies: 3Last Post: 2nd Jul 2010, 12:08 -
VirtualDub to sony vegas problem HELP
By iTzRingoBrown in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2010, 21:50 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
With
