i have a canon hg20 60gb hard drive and would like to copy/transfer to my mac.
what is the best way to do this. i am new to all this and would like help, thank you.
If you recorded to an SD card, plug it into your Mac or use a card reader to do so. If you recorded to the HD, plug the camcorder (using the USB port) into your Mac and drag over the clip files. According to the specs on Canon's webpage, it shoots AVCHD so, depending on the format it actually is, the files will either drop directly into iMovie (versions newer than v6) or may have to be converted to something that may be edited. ClipWrap should be able to do this. Please advise how it goes.
Archiving and Working with AVCHD on a Mac
By monteric in forum MacReplies: 5Last Post: 10th Jan 2010, 12:56 -
Can I convert to AVCHD on my mac for playback on BD60?
By chobbs in forum MacReplies: 3Last Post: 23rd Nov 2009, 12:31 -
Creating an AVCHD DVD disc on a mac
By mattr in forum MacReplies: 11Last Post: 31st Oct 2009, 04:59 -
eXport AVCHD --> Prores422 Premiere CS4 (mac)
By _eXtreme_ in forum Video ConversionReplies: 3Last Post: 17th Jun 2009, 17:04 -
Mac AVCHD encoder
By bertoa in forum MacReplies: 3Last Post: 23rd Jun 2008, 08:16
