I have an AVI file that I can play just fine on my Mac with VLC, but when I burn it to DVD (and Toast converts it from PAL to NTSC), it doesn't play the sound on my PS3. I don't know if it's the audio encoding to begin with or if it has anything to do with the PAL-NTSC conversion. Here are the specs of the file from VideoSpec:
***** First Analyzed File Results *****
*** General Parameters ***
- Name: BOB_THE_BUILDER_SERIES_1.avi
- Container: AVI - Audio Video Interleaved
- Creation Date: 2008-12-09 11:56:26 AM
- Size: 700.0 MiB
- Duration: 1:31:38
- Bitrate: 1 068 Kbps
- Encoding Library: VirtualDubMod build 2178/release
- Encoding Application: VirtualDubMod 1.5.4.1 (build 2178/release)
*** Video Track Parameters ***
- Format: MPEG-4 XviD video
- Size: 617 MiB (88%)
- FourCC: XVID
- Track number(s): 0
- Bitrate: Max.: Undefined
Average: 942 Kbps
Min.: Undefined
- Frame rate (fps): Max.: Undefined
Average: 25.000
Min.: Undefined
- Bitrate mode: Undefined
- Encoding profile: AdvancedSimple@L5
- Resolution: 24 bits
- Width (Pixel number): 512
- Height (Pixel number): 384
- Pixel Aspect Ratio: 1:1
- Display aspect ratio: 4:3
- Chroma subsampling format: YUV420p
- TV standard: Undefined
- Interlacing: Progressive
- Encoding library: XviD 1.3.0.dev55
- Additional Parameters: BVOP: Yes
Quarter Pixel: No
Global Motion Compensation: No
Matrix: Custom
Bits/(Pixel*Frame) ratio: 0.192
*** Audio Track(s) Parameters ***
- Format: Mpeg-1 layer 3 (mp3)
- Size: 74.1 MiB (11%)
- FourCC: 0x55
- Number(s) and language(s): 1: English
- Details: -
- Profile: Layer 3
- Bitrate: 113 Kbps
- Bitrate mode: Variable
- Resolution: 16 bits
- Rate: 48.0 KHz
- Channel(s): 2 (stereo)
- Position: Undefined
- Encoding Library: LAME3.97
- Additional Parameters: Not available
*** Miscellaneous ***
- Subtitle(s): No Subtitle
- Metadata: Album: Undefined
Part number: Undefined
Track name: Undefined
Track name number: Undefined
Performer: Undefined
Screenplayer/Writer: Undefined
Genre: Undefined
Encoded date: Undefined
Comment: Undefined
Album artist: Undefined
Grouping: Undefined
Copyright: Undefined
Thread moved to mac forum and no more crossposting please.
Apparently my previous response was in one of your other threads.
When you burn the avi with Toast, are you burning it as data, or converting it to DVD ?
If you convert it to DVD, does the DVD play correctly in your Mac ?
We need to see the specs for the converted file, as that is the file that does not play.Read my blog here.
Can't hear audio on PS3 from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2010, 15:49 -
PS3 won't play audio for this file (specs included)
By bound4h in forum AudioReplies: 1Last Post: 21st Jul 2010, 20:16 -
PS3 won't play audio from AVI (specs included)
By bound4h in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2010, 20:16 -
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22 -
PS3 won't play AVI's after splicing.
By zsaz1029 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2008, 08:59
