I have the Hauppauge HD-PVR which I use to record tv shows. I can only record to m2ts, ts or mp4 files. I would like to mask the bottom of the video with a black bar, but without re-encoding the whole video. Can this be done ? I know I can mask using Virtualdub, but not under directstream, so I can only save the file in avi format, which means re-encoding to get back to m2ts.
Is there a software that can mask in m2ts format and do not need to re-encode the whole file ?
Any time you change a video the process involves decompressing the video, making the changes, then recompressing. So no, you cannot mask the bottom of the frame without re-encoding.
Problem with masking in after effects cs4
By Morten in forum EditingReplies: 6Last Post: 16th Aug 2009, 08:52 -
vegas masking?
By wingfan in forum EditingReplies: 12Last Post: 26th Feb 2009, 22:43 -
Masking a video
By MrKipling in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2009, 10:23 -
Masking onscreen items
By Rogert in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 12:58 -
Masking or pixilisation of 'portion of image'
By Thibor in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2007, 23:39
