Hi guys. I have a VHS tape that NO ONE has been able to capture. I have tried a number of video stablizers with no joy. I have a Pinacle avdv capture card which looks past macrovision (usualy) and a canopus advc300 no to capture. I have take it to 2 shops and they have had no luck at all either. Any one heard of this before?
Direct to tv it looks amazing, try to capture and it goes light to dark.![]()
Results 1 to 18 of 18
Where did the tape come from? Is it PAL or NTSC? Is it a first generation or a copy of a copy of a copy?
1st gen store bought from korea. NTSC. It is Michael Jackson HIStory Tour Seoul
Well I wouldn't trust the Pinnacle nor the Canopus for defeating the macrovision. You need a full-frame TBC like the CTB-100/AVT-8710.
Although I have read that there is a "secret" way to disable macrovision for the Canopus units -
Hold down the input/output toggle for about 20 seconds. If you're watching the video out, you'll see color bars come up, then after, color bars go away. Once they go away, macrovision is disabled until the box power cycles. -
tried that and 6 others
this company replaced twice cause they were that sure it should work
http://www.xdimax.com/grex/grex.html -
Hech54 posed questions that need to be factored into the equation. Although the light/dark shifts are classic symptoms of Macrovision, perhaps there is greater difficulty defeating it because of the NTSC/PAL situation. I take it your VHS unit is multi-standard? Are your capture settings PAL or NTSC? And, as hech54 also asked, is the VHS an original or a copy? (If it's a copy, light/dark shift may have actually been recorded onto the tape.)
Here on European PAL equipment....we too can watch any NTSC VHS tape...but it is damn near impossible to record or capture it because the VCR does NOT output a true NTSC or true PAL signal. Well documented.
Most likely a standards mismatch of tape to hardware, as others have noted. Know any recent immigrants from North America who might have brought their VCRs with them? Or have any friends in USA/Canada you can send the tape to? If they can't get it to work, then something is hopelessly funky with the tape. I wouldn't rule out the chance its a high-quality bootleg if you got it in Korea, such tapes can be really difficult to process.
The tape is a GENUIN release of the Michael Jackson HIStory Seoul concert. It was shrink wrapped when i recieved it.
My vcr gives the option of NTSC PB (NTSC on PAL TV) NTSC 3.58 and NTSC 4.43. This needs 3.58 (i think) 4.43 goes black and white -
I have a Dazzle DC150 boxed away. It was manufactured before the DCMA rules were eforced and I never had problems with it. You might be better off using a capture device created before 2002.
Well 'shrink wrap' means nothing. There is a massive far-east industry in 'factory-created' fakes. Your tape will be NTSC. Your vcr will be able to play that back on a Pal tv but the output from the vcr is not pure pal nor is it ntsc. It is a hybrid often called Pal60 - there are tons of threads on here about it and the equipment you need to be able to capture such material. A ADVC300 can not either in its PAL or NTSC setting but you may be able to feed the signal through this device to a capture device that supports Pal60.
macrovision copy
By Blackband in forum DVD & Blu-ray RecordersReplies: 43Last Post: 6th Mar 2014, 15:17 -
Macrovision Question
By matthewjohn23 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 7th Jun 2011, 15:19 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 16:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 20:41 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 10:37
