Hi,
I have a Noontec V9 DVR which records in TS format. MediaInfo on the files is (for example) shown below.
I think - and here I could be wrong - it must be possible to "convert" the file into a PS type of file without trying to transcode or anything complicated.
I don't have any joy playing it with VLC, I get messages like:
ts warning: first packet for pid=512 cc=0xf ts warning: first packet for pid=650 cc=0x8
direct3d warning: trying surface pixel format: YV12
main warning: vlc_object_find_name(postproc) is not safe!
main warning: decoder/packetizer fifo full (data not consumed quickly enough), resetting fifo!
It plays fine on the Noontec itself, and on a WD HD LIVE TV unit I have.
I have tried using TSCONVERTER to convert it; it goes through the motions but produces nothing.
I believe my problem is that I am missing an appropriate MPEG-2 Muliplexer, as in the options I can choose the ffdshow in AC3 Analyser, , but there is only <auto> listed in the Multiplexer tab.
I also get a series of errors in the log like:
[23:25:56] Conversion starting..
[23:25:56] Filters in use:
[23:25:56] Media Player Version: 11.0.5721.5260
[23:25:56] HDTV Pump Version: 1.2.0.0
[23:25:56] Starting DVR-MS recording
[23:25:56] Starting recorder
[23:27:34] Media control: graph stopped
[23:27:34] Stopping the recorder
[23:27:58] SetAttribute retry: 20100523 dr who, cause=0x8000ffff8
[23:27:59] SetAttribute retry: Movie, cause=0x8000ffff8
[23:28:00] SetAttribute retry: en, cause=0x8000ffff8
So, any explanations, or better suggestions?
Many thanks.
TS file Data:
General
Complete name : C:\Documents and Settings\Fred\Desktop\20100704_19_30.ts
Format : MPEG-TS
File size : 2.02 GiB
Duration : 1h 0mn
Overall bit rate : 4 821 Kbps
Network name : ABC Perth
Video
Menu ID : 739 (0x2E3)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 59mn 59s
Bit rate mode : Variable
Bit rate : 4 325 Kbps
Nominal bit rate : 10 000 Kbps
Maximum bit rate : 6 642 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.417
Stream size : 1.81 GiB (90%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 1h 0mn
Bit rate mode : Constant
Bit rate : 256 Kbps
Maximum bit rate : 288 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Video delay : -546ms
Stream size : 110 MiB (5%)
Language : English
Text
Format : Teletext
Maximum bit rate : 86.4 Kbps
Language : English
Menu
List : 512 (0x200) (MPEG Video) / 576 (0x240) (Teletext, English) / 650 (0x28A) (MPEG Audio, English)
Language : / English / English
Maximum bit rate : 350400
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
Problems converting HD Mpeg
By fearmyrage in forum Video ConversionReplies: 3Last Post: 7th Jun 2007, 22:46
