  1. Hey guys I have a movie ( 2010 720p mkv 8.74gb )
    When I watch this file on my PC it works fine ( in WMP I can turn audio commentary on and off )
    Although i want to watch it on my PS3 so tsMuxeR and split it to 4gb files ( as per setting here http://img832.imageshack.us/img832/9255/tsmuxer2012.jpg )
    When I play back the m2ts on my PC it seems it has merged the normal audio and directors commentary into one.
    It looks like the bottom one is the commentary? but if I untick it then there is no sound at all.
    Anyway to watch this movie properly on my PS3? / any heads up?
  2. I think I know what the problem is - the main audio is DTS which is not supported by PS3
    Can tsMuxer convert the audio from DTS to AC3 or do I have to put it through another process? - any heads up on the best way to do this?
  3. far out what a great friggin forum just answering my own questions here - I'll share anyway
    use XviD4PSP to extract and iencode audio in AC3 and bring it together in tsmuxer ( remove other audio channels )
  4. Glad you found a way to do it. Personally, I would use EAC3toGUI.
    Pull! Bang! Darn!
