  1. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    In ffmpeg command line I can make an MKV from whatever input file by
    FFmpeg -i myfile.xyz -vcodec copy -acodec copy myfile.mkv
    This doesn't reencode the video or audio streams, just remuxes them into an MKV. (Useful for Flash, for example.)
    I've looked a few ffmpeg GUIs (there are dozens...) and wonder if any support this feature?
    GUIs like for instance Xmediarecode uses ffmpeg and have useful presets for various devices; but not, as far as I can work out, one that just lets you copy the streams into a different container.
    I can and do just use a batch file as above, but ffmpeg's command line is so damn complex and poorly documented and has dozens of slightly different builds, it takes hours fpr me to work out a good script, I end up Googling through a dozen forums and finding snippets of code to give me hints. It gets tedious.
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Originally Posted by DarrellS View Post
    Thanks, but I know how to write batch files. It's not scripting loops that's hard, I do that every day, but working out the best ffmpeg options.
    So far I haven't found ANY gui that gives you access to all of them.
  3. Member ricardouk's Avatar
    Mar 2005
    Portugal
    you can use avanti, select "copy audio" and "copy video" options and select container, its portable and free and what i use when changing containers.
    I love it when a plan comes together!
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Thanks, that has the options I need, and gives access to the ffmpeg and Avisynth commands it uses too; very useful to use in my own scripts.
