I'm trying to make a AVCHD DVD5 out of a 2GB MKV. So far, I've been looking all around the web, and all I've found is that is you increase the bitrate, the quality will get better.
I already know that is a myth.
So, the real question is... If I reconvert the mkv to avchd, will I lose quality although the bitrate will be increased?
(I'll be using multiavchd for this project.)
Closed Thread
Results 1 to 11 of 11
Burning a Blu-ray is the next achievement. ;)
Post mediainfo (view txt, cut and paste here). It depends what the MKV contains.
http://www.kiva.org/about
Problem with axioms like those are that they are too simplistic.
That's like "If I don't shoot you, you won't die."
Even the reverse isn't completely true (If I shoot you, you'll die), as there are clearly exceptions.
One main rule of thumb that you should follow is this:
The reverse to this would have been that if you don't recompress, you don't lose quality - THAT IS TRUE.If you have to recompress, you will lose some amount of quality.
Now, the "SOME" amount can vary, depending upon many factors.
Another video rule of thumb that you can at least start using as a general guideline is this:
Now, this uses elements which are a little fuzzy, like "Efficiency", "Complexity" and "Quality". Sorry, can't get much more exact than that.(Bitrate x Codec Efficiency) / (Resolution * Complexity) + Resolution = Quality
What you should know is that (for a given bitrate) MPEG2 is more efficient than MPEG1, MPEG4 (ASP) is more efficient than MPEG2, and MPEG4 h.264 is more efficient than MPEG4 (ASP). Complexity has to do with the scene: randomness, fast cuts/action, sharp contrasts, etc. Note that lowering resolution will in one way make the quality better because you have more bits per pixel, but will in another way make it worse because you have less visual clarity. It's often a trade-off.
Even with these "fuzzy" parameters, you can get a good idea of areas to tweak to get the "Quality" that you want.
I'm no longer going to hide the fact that I downloaded this from the net... but here's the MediaInfo.
General
Complete name : Clash of the Titans (2010) BDRip m-720p x264-McClassick.mkv
Format : Matroska
File size : 2.33 GiB
Duration : 1h 46mn
Overall bit rate : 3 141 Kbps
Encoded date : UTC 2010-07-15 23:35:24
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 46mn
Bit rate : 2 500 Kbps
Width : 1 280 pixels
Height : 528 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.154
Stream size : 1.81 GiB (78%)
Writing library : x264 core 77 r1292 e381f6d
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 46mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 486 MiB (20%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Now according to other threads, AVCHD compliant material has to have a resolution of 1280x720 for this to work( 1440x1080, 1920x1080, 1280x720, 720x480/576 are also "compliant"). As you can see, it is not compliant as it is 528p.
What I understand to do now is add black bars using multiavchd and recode, but the thing is: If I reencode, even if I'm NOT re"compressing" it, is it still possible to lose some quality even though the bitrate would be higher than the source?
That puzzles me.
(The bitrate shown in multiavchd had a rough estimate of over 4000 kbps.)Burning a Blu-ray is the next achievement. ;)
Yes. Reencode=recompress. The process involves decompressing the source, adding borders, then recompressing. If you use enough bitrate the loss of quality will be minimal. Maybe not even noticeable.
Since you left the filename in your MediaInfo post, and admitted to downloading the file, you're thread will likely be locked.
How to increase the bitrate of a video by avisynth ?
By avengerevenge in forum EditingReplies: 31Last Post: 11th May 2013, 01:13 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48 -
HOw come .iso files lose quality
By ninjinturdle in forum DVD RippingReplies: 2Last Post: 8th Dec 2010, 09:52 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 10:23
