Hi, I have a problem and am hoping this is the right place for it.
I bought a copy of Code Monkeys Season 1 on DVD, and there are issues with some of the episodes. It's a set of 2 DVD's containing all episodes from the first season. The first episode that plays on each disc looks perfect, but the episodes after them look weird. I'm not sure how to explain it, other than there is noise and it moves around (typically around the drawn lines, not blank areas). I've uploaded a picture that would hopefully help visualize it.
Could this possibly be the discs, or did the DVD manufacturers screw up?
Either way, is there some setting during the encoding process (ripping the DVD) that would fix it? It's obviously not interlacing, but I tried ripping an episode and using de-interlacing anyway (which didn't work).
Dot crawl, chroma noise.
Exactly, I looked up the dot crawl one, and it looks exactly like that, sort of like a bad rgb cable or something, but I've watched it on both the computer and ps3, so it's definitely not a cable problem or anything.
It was probably transferred/encoded that way, from composite connections.
Not a good DVD from the production company.Want my help? Ask here! (not via PM!)
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 09:58 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
