Well I thought I could find the answer but after days stumbling around the net I'm stuck
All my video is on a WHS served via PS3mediaserver to my PS3 (gigabit LAN!). I'm using XviD4PSP v5.0.37.8
I have a Panny TM700 and shot a bit of footage in 1080 60p. If I copy the M2TS file straight onto the media server the PS3 plays it; ish...
Previously I've done 1440 1080i footage I've converted to 720 50p and this plays fine. Obviously I can convert down to this from 1080 50p, I was just wondering if there was anything I can convert to now whilst the Blu-ray standard lags behind the proprietary Panny 1080 50p but still retaining the full frame? I've tried an MP4 but the audio from the TM700 is in 5.1 AC3 which isnt supported. For some reason XviD4PSP doesnt convert it to AAC![]()
Media info for 1080 50p stream -
General
Complete name : D:\original.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 221 MiB
Duration : 1mn 13s
Overall bit rate : 25.3 Mbps
Maximum Overall bit rate : 28.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 1mn 12s
Bit rate : 23.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.231
Stream size : 208 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1mn 12s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -40ms
Stream size : 3.34 MiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Duration : 1mn 12s
Video delay : -40ms
Results 1 to 1 of 1
AVCHD Spec Version 2.0 Updated 1080/60p , 50p
By poisondeathray in forum Latest Video NewsReplies: 6Last Post: 8th Jul 2011, 02:45 -
1080 60p PC output into a Black Magic Intensity?
By crispy1138 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Feb 2011, 12:14 -
1080 60p video footage
By j_kwock in forum Software PlayingReplies: 29Last Post: 9th Oct 2010, 04:24 -
1080/60p camcorder output via HDMI into Mac
By Trilomac in forum Newbie / General discussionsReplies: 18Last Post: 28th Jan 2010, 20:42 -
1080 hd ps3
By Josh Mickens in forum DVB / IPTVReplies: 2Last Post: 16th Apr 2008, 08:40
