What does this mean. Im just trying to load a video clip into virtual dub so i can adjust the length, but its giving me this error. What do I do to fix this
Install the Xvid codec. Or some other VFW decoder that handles Xvid, like ffdshow.
cool. it works now. Now how do I adjust bitrate on dvd flix. I have a bunch of videos that add up to 4.96 GB even after doing the tweaking with virtualdub. I cant cut them any more to make them have less GB. So I need to tweak the bitrate so that the clips will fit on a dvd disk. How do I do that
If you want to reduce the total file size, and you're not willing to cut anything out, you have to reencode one, some, or all of your videos with a lower bitrate. The basic procedure is to open a video file in VirtualDub, select Video -> Compression... highlight the Xvid codec and press the Configure button. From there you pick the bitrate you want. 2-pass variable bitrate will give you the best quality for the selected bitrate. Use a bitrate calculator to determine what bitrate you need to fit your files on a DVD.
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 18:49 -
how we can implement "VirtualDub" or "FFmpeg" with my C# windows applicati
By dhemittal in forum ProgrammingReplies: 0Last Post: 8th Jun 2010, 08:17 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
VirtualDub "NewMovieFromFile" error w/mp4 file
By smk42 in forum EditingReplies: 3Last Post: 31st Dec 2009, 01:37 -
VirtualDub "format convert" audio filter - how do I use it?
By Jedi787Plus in forum AudioReplies: 0Last Post: 12th Sep 2009, 16:35
