I would like to learn how to use Avidemux 2.5 to insert a title frame into the beginning of the video, and save them together as a complete file. Thanks a lot!
One way: make a title image the same frame size as your video, eg as a PNG.
Open this in Avidemux.
This will give you a one frame video. You can "Append" as many copies of this image as you like, adding one frame at a time.
Then Append your video.
This is a bit tedious, there is probably an easier way, but it works.
To make a longer title sequence, you could say append 8 images, save that as an AVI, (make sure to set the same fps as your video) then open that and append multiple copies of this file to itself. Save and reopen a few times and you can double the length each time. Configure the video to be "high quality" so you don't lose much when you save and reopen. When it's long enough, append the actual video and save.Last edited by AlanHK; 20th Jul 2010 at 03:36.
I've used about the same method AlanHK mentioned, with VirtualDub. After you duplicated about four frames, you can duplicate and paste them all, then you have four+four. Then eight + eight. It doesn't take that long to get enough, figuring roughly 30 frames per second. I'm sure there are better ways, but whatever works.
You can probably also add fade-in/fade-out if desired on the ends with the proper filters.
Thank you all! You guys are truly so enthusiastic about helping each other. I really appreciate that. I have understood all your instructions and I have resolved the problems. Thanks again!
how to insert an i-frame in AVIDEMUX2
By shparekh in forum Video ConversionReplies: 5Last Post: 24th Aug 2011, 06:39 -
Want to insert image onto a gif...
By zhemp in forum Newbie / General discussionsReplies: 0Last Post: 4th Aug 2011, 13:23 -
Is it Possible to Insert a GIF Into Another Video?
By PancakeMachine in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2010, 12:36 -
Insert animated gif in movie clip - avi, swf or else
By wilderwildness in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 08:45 -
Any way to insert 1 frame image at the beginning of an mp4 (using AutoGK)
By cryptyk in forum DVD RippingReplies: 11Last Post: 10th Sep 2008, 22:03
