    May 2007
    Hello,
    I just transferred a home movie on VHS to a DVD-RW. The disc has been finalized and I now would like to transfer it to my PC (Windows XP) as one avi file.
    I've downloaded AutoGordianKnot. Is that the proper program to use?
    Dec 2005
    Canada
    Typically you would drag the VIDEO_TS folder off the disk onto the Desktop
    Run AutoGK.
    Select the source file: VTS_01_0.IFO from the VIDEO_TS folder
    Select 'Target Quality'
    'Add Job'
    'Start'.
    May 2007
    Excellent, thanks for the help.
