Results 1 to 15 of 15
    Jan 2009
    Honduras
    Hi,
    Could someone tell me how make available setup menu?
    I have 1 audio and 3 subtitles, in menu preview appears setup but in final AVCHD don't appears....
  2. It is not supported in AVCHD [strict] mode.
    Laugh and the world will laugh with you. Cry and you will be alone
    Jan 2009
    Honduras
    Hi,
    Thanks for the reply.
    how chapter names works in your new update?
  4. Laugh and the world will laugh with you. Cry and you will be alone
    Jan 2009
    Honduras
    Hi,
    Which are difference with AVCHD relaxed and strict mode?
  6. Strict mode uses static menus, 1 chapter page with 12 chapter thumbs, no popup menu, no titlelist menu, no motion menu/chapters, no setup menu, works with Panasonic players.
    Jan 2009
    Honduras
    Hi, Dean.
    I've been using AVCHD Strict mode...for my Philips Blu-ray Disc player BDP3000 and never the relaxed mode...so, if better used Relaxed mode for many BD players includend mine? or is limited? I want a full setup menu, pop up menu and more function but I've been thinking that the best mode is AVCHD Strict...
  8. It is better to use AVCHD relaxed. It works in ALL players EXCEPT the Panasonic ones.
    Jan 2009
    Honduras
    Hi, Dean.
    Thanks for your help.
    I have just a couple (10) AVCHD movies with your software and I wanna make it again with Relaxed mode...could you send me your better settings? like the file that we save in custom mode (personal setting)
  10. You can drag all these AVCHD folders to multiAVCHD and select AVCHD Relaxed mode.
    Jan 2009
    Honduras
    Hi, Dean.
    thanks again...I gonna make my movies with AVCHD Relaxed.
    Jan 2009
    Honduras
    [AVCHD for DVD/BD-R]
    * Long filenames
    * UDF 2.50/2.60 file system required
    * Supports menu
    * Complies with AVCHD version 1
    * Stricter AVCHD folder format option is recommended (only standard folders)
    * Media: DVD-R/DVD-RW/DVD+RW/BD-R/BD-RE
    * Playback compatibility: Playstation 3 and most Blu-ray players via optical media, software players
    http://multiavchd.deanbg.com/tutorial.php
    For this reason I just used Stricter...I guess I was confused....
    Jan 2009
    Honduras
    Hi, Dean.
    AVCHD Relaxed works good....with all that I need, just let me know how can added more than 12 chapters?
  14. When you click a title name (or [properties]) you'll see a chapter list and "Chapters" tab. There you can put as many chapters as you wish.
    Jan 2009
    Honduras
    Hi, Dean.
    Thanks for your help...because I've been working with AVCHD Strict I guess that's what just appears 12 chapters...
