I'm currently using XMedia Recode and was wondering if there way to add the .srt file to the AVI I want to convert to an MKV so it will be embedded as an subtitle option, but not burned in on the screen.
You might be better off just using mkvmerge (mmg.exe for the GUI, as I recall) in the mkvtoolnix package, to mux the .srt file into the finished MKV as a soft subtitle stream.
If cameras add ten pounds, why would people want to eat them? -
Does XMedia Recode not have an option to add a .srt when I encode?
I really don't want to have to download another program again just for MKV files -
mkvtoolnix is a good set of tools to have around if you're working with MKV-container videos.
Add MKVExtractGUI-2or MKVExtractGUI to the same folder as mkvtoolnix, and you'll have a GUI setup to extract streams from an MKV, as well.
For AVI, I think AVI-Mux GUI may be what you want (haven't muxed anything into an AVI container in a while, and I usually just do it in VirtualDubMod, anyway.
For MP4: MP4Box. Though, if you use YAMB as the GUI for MP4Box, you might want to use version 1.6, if possible, and stay away from the beta versions. A number of people have apparently had a problem with it deleting or otherwise messing up their Start Menu folders when uninstalling.If cameras add ten pounds, why would people want to eat them? -
Well I appreciate your suggestions, thanks.
But this is all pretty much what I wanted to avoid, which was having to install three additional programs where only one would be desirable.
XMedia Recode works very well but I don't see a subtitle option to add a SRT and that's all I'm really looking for is the ability to be able to do this. -
I'm not really aware, offhand, of any straightforward converter that handles softsubs properly when converting. Most of the time, you'll probably end up having to demux the subtitle streams and then mux the subtitles into the converted file (or hardsub, if you prefer).
Help please, unable to merge srt to avi using AVIDEMUX
By pwangdel in forum EditingReplies: 9Last Post: 16th Jun 2016, 03:08 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 03:42 -
How to demux .srt from mkv, then convert .srt to .smi and mux .smi to mkv??
By narayanan in forum SubtitleReplies: 1Last Post: 7th Aug 2010, 22:49 -
video (xvid, avi,mkv...) AND sutbtitles (SRT) splitter
By kkm in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2010, 16:58 -
Merge two AVI's & SRT's into one MP4
By vassie in forum Video ConversionReplies: 6Last Post: 18th Sep 2009, 04:00
