Hi,
I have a Canon Elura 90 DV camcorder. I've tried three different applications (Nero, PowerDirector, Win MovieMaker) to try and capture video from a DV tape to my hard drive and the capture always starts just fine but locks up after some random period of time (e.g. anywhere from 30 sec to 20 min). The camcorder continues to play but nothing is being captured and it seems that the software is locked up or has lost communication with the camcorder.
Does anyone have any suggestions ? I have a Nexxtech n3pfwpc firewire PCI card and have read that no drivers are needed with WinXP. Could it be the firewire card ? Are there Canon drivers required ?
Thanks much for any help!
	Hi bj4jc
 I am having a similar problem, did you ever work out the cause and a solution to your Canon Elura 90 capture issue?
 Thanks,
 Richard
	Hi Richard,
 I can't say for sure that I ever discovered the exact source of the problem, but I suspect it may be a hardware problem related to the DV capture card in my PC. The Nexxtech DV capture was a cheap one and probably doesn't have much memory/resources on the card itself.
 I wound up trying two things that seem to be getting me by: (1) I plugged the firewire cable into a different port on the 3-port capture card. (2) I've been using Windows Movie Maker to capture the raw avi video from my camera. And then I go back to PowerDirector 8 to edit and produce. PD8 is where I was having most of my original capture problems.
 Finally, I have to say that I've only captured short (i.e. < 15min) clips for some time now. If I tried longer clips I may still run into the same problems. Not sure.
 Hope this helps,
 Joey
  Canon HV40 capture problemsBy stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 22nd Feb 2011, 18:16
  Canon Elura - Tape capture between models doesn't work Help?By jbrajuka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th Nov 2010, 06:58
  Canon Elura 90 driversBy pacific77 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 29th Apr 2010, 15:43
  HD Capture from Canon HV-30 to Intensity ProBy liberty610 in forum Capturing and VCRReplies: 18Last Post: 27th Dec 2009, 20:14
  Help! Canon HV20 capture problemsBy jmunns in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 21st Nov 2007, 11:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
