Today I tried to author 1 disc with two separate titles on it.
1 was the movie in 1080i HD (MPEG-2) and the other was the trailer for the film in 480i (MPEG-2).
The movie came out perfectly, with no problems.
The trailer, on the other hand, is unplayable. There are digital glitches all over the place.
Does anyone know why this may have happened? Can you not mix HD and SD videos on the same disc?
Did you create AVCHD/Blu-ray or HD-DVD disc with multiAVCHD?
The glitches in the trailer could be caused by unsupported coding format. There is no problem to have mixed resolutions/framerates on one disc.Laugh and the world will laugh with you. Cry and you will be alone -
Problem with multiAVCHD...
By hiimbored in forum Authoring (Blu-ray)Replies: 7Last Post: 2nd Jun 2015, 10:14 -
multiAVCHD problem
By obadvw in forum Authoring (Blu-ray)Replies: 2Last Post: 17th Nov 2011, 16:02 -
Audio encoding AAC to AC3 for multiAVCHD authoring
By ejai in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Dec 2010, 11:00 -
Multiavchd disc wont play in PS3
By cougarve in forum Authoring (Blu-ray)Replies: 28Last Post: 30th Aug 2010, 08:28 -
Need help by authoring/Burning AVCHD DVD (multiAVCHD/ imgBurn)
By benji179 in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2010, 17:20
