    Jul 2010
    perth
    Hi All
    I have a netgear eva2000 media player and im streaming mms website to it with no probs
    I am now trying to stream mjpg sites, I can see them on the tv but they stream really fast then stop then really fast again and on and on
    how do i make it stream smoothly?
    An example site is http://165.91.110.101:2010/mjpg/quad/video.mjpg
    I use wild media server to connect with my media player
    thks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just to state the obvious you aren't downloading or uploading anything else while watching are you? If so that will effect the speed if you are taking these off of a website and not from your local computer.
    Jul 2010
    perth
    Hi
    no, nothing is being downloaded, it just runs very quickly stops for 2 seconds then does the same thing
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Try downloading the file to a computer. Play it back on the computer and see if it does the same thing. If it does than that means the file wasn't produced properly and you won't be able to watch it correctly regardless of your setup. Other than that I'm not sure I can offer much else.
