Basically im trying to play an mkv movie on my television using the built in usb port. and everytime i play it, it plays with black bars top and bottom. there is no zoom function of the tv to stretch the picture so im trying to do it using software
i need some sort of software to stretch the picture out to too full screen. ive tried mkvmerge but it only changes the display height/width and i need to change the actual pixel height and width. i also tried changing the aspect ratio to 16:9 and 4:3 but it still plays with black bars
the current dimensions are 1280 x 544 on the mkv video.
Results 1 to 18 of 18
The movie is wider than your TV. That is, the aspect ratio of the film is 2.35:1, while your TV is 1.778:1 (16:9). The video is not meant to fill the screen, and if you had actually purchased this video instead of downloading it, it still would not fill the screen. There are only two ways to make it fill the screen. The first is to resize it to 1280 x 720. This will make everyone appear stretched tall and thin and will look stupid. The other way is to zoom the image in an editor until it is 720 pixels tall, then crop off the ends so it is 1280 pixels wide. You will lose around 25% of the image.
Or you could just stop carrying on about black bars and watch the movie the way it was shot. A large proportion of widescreen movies are wider than 16:9 and will have black bars. Are you going to butcher every one of them ?Read my blog here.
well i bought a big tv for a reason, and thats to fill up the space, can you help me resize it too 1280 x 720?
i cant find any software to do this. -
You wasted your money. They aren't meant to fill the space.
Search the forums for cropping and widescreen and you will find plenty of posts. Most will tell you not to do it - aside from the butchery you will lose quality through resizing and re-encoding - but many will also tell you how to do it. If you really want to do this, you will have to work out the rest without me. I simply don't understand your problem.Read my blog here.
yeah but it always asks me to covnert, all i want to do is change resolution without losing any big difference is quality
give me software names -
Upsizing in software is always lossy and also requires a full decode-recode generation loss. Most HDTV sets have zoom functions that are less lossy since they are resizing in hardware. A 1280 x 544 source file needs to be upsized by your TV hardware to native display resolution (usually 1920x1080 or 1366x768).
http://www.kiva.org/about -
tell stupid samsung that.
they put the zoom feature on the newer models but cant be bothered to add it to my model. i could get one of them network streamers that plays files via usb and can stretch etc.. but im worndering if i could at least try the software method and see if it works -
If you fill the screen so you dont see the black bars then you lose some of the picture from the sides.you can resize the picture to 1280x720 and fill the screen with avidemux and re-encode and lose some quality and you lose about 207 pixels per side.
Or watch a soccer game and don't see the goals
what video codec should i use to under video? im not sure which is the best format
does it have to be re- encoded, isnt there a way without re encoding to change aspect ratio/resolution
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 19:25 -
Can't get aspect ratio 16:9 to fill the screen when play DVD movies.
By Herbert Smith in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Sep 2010, 06:37 -
how to change mkv aspect ratio?
By johnnysv in forum Video ConversionReplies: 4Last Post: 27th Apr 2010, 02:51 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 11:01 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 09:21
