Results 1 to 12 of 12
  1. I have a Windows XP computer with 2ghz and 80 gig hard drive and a CDR Drive and a DVD drive and all I want to do is copy some of my DVD's over to VCD. What is the easyest program to use to do this and I am a newbie so I need it to be real simple. I tried Dup-dvd but I cant get it work? All I get is "Image" on the Source Drive? Can anyone help Me?
    Hawkredtail
    Jun 2001
    England
    A lot of people here started off with Sefy's classic newbie guide.
    http://www.vcdhelp.com/dvdtovcd.htm
    It may look complicated at first but you'll soon get the hang of it.
  3. Wow, if my guide looks complicated, then please tell me, and I will try making it simpler as possible, but I can't know if i'm not told.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Jun 2001
    England
    LOL.. Your guides are only as complicated as they need to be.
    I'm sure that I'm not the only one here who used your guides as a first foray into the world of DVD, VCD and digital video.. even though it was over 18 months ago now!
  5. Well, I sure hope i'm managing the make the guides simpler as I progress with themm I can only be as good as the comments I get about them
    Best Regards,
    Sefy Levy,
    Sep 2001
    N/A
    than use my guide, simple and good!
    Baker
    My vcd & cvdGuide
  7. hey Baker,today I printed your guide,but in the output setting I can't get the Premiere plugin encoder,I installed the panasonic plugin in the same
    directory where dvdx is,but is not there,do you know what is the problem?
    thanks
    Rigo.F
    Dec 2001
    United States Boise Idaho
    YOUR GUIDE KICKS-ASS My vcd collection is proof alone. Thanks for all the info you provide here.
    Sep 2001
    N/A
    make sure you install the plug-in and not the standalone with my program
    Baker
    My vcd & cvdGuide
  10. hi baker i think i will try your guide tonight i have the panasonic plug in ill just download dvdx soon . The movies i will be ripping are dvd silvers which are ntsc format , what settings should i enter differently to that on your guide ?
    Is the settings on your guide about the best quality picture you can get ? Is it worth using the filters ?
    The Quantizer Matrix - should i set this to amimation for cartoons like A Bugs Life ?
    Any tips would be greatly appreciated .
    sorry for jumpin on this post .
  11. Has anyone here seen the latest revision of the guide ?
    http://www.digital-digest.com/dvd/articles/dvdtovcd/index.htm
    It's completly redesigned, and covers nearly every program there is.
    Best Regards,
    Sefy Levy,
  12. Tried to use "Burn DVD to VCD/SVCD/Avi(DivX) in CD-R/RW", but there is password required when I tried to unzip the file. Do we have to purchase a password?
