When i play a video, be it a rip from VHS, digital tv or even a bought dvd on my PC, the video is pixelated (flyscreen like) and fuzzy. If i play the same video on another computer or a tv or projector, it crystal clear.
Any ideas what may be causing this.
I have tried different graphic card (a little bit better after this)
different media players (WMP, Nero 8 player, VLC player, Power DVD 10, Sony Vegas (shows the worst) and TMPGEnc Xpress (pretty bad)
Re-installed windows before
Results 1 to 30 of 30
Personally, I would not download and install any codec pack. You don't need one. A codec pack is a lazy answer that is at best going to do nothing to help you, and at worst install a large number of codecs that you don't need, and whose settings you don't understand.
I have never found a software player that gives an image as clear as a TV on a computer monitor. Ever. That includes everything from Total Media Theatre (very good) through PowerDVD (different incarnations) and down through various free options like KM Player and VLC. For the most part the quality is the same, as the underlying playback engines are either the same or very similar.
The first thing I would be checking, from your description of the video, is that you aren't running in 16bit mode. Check both your graphics card settings, and your player.Read my blog here.
can u use vnc viewer to check my settings? i have looked around with no joy
I give up. This is insain. I cant find what is causing this. My laptop plays it better then my Geforce 9800 and PC
done all that. i have 2 lg flatron w1942t and both have same problem
yeap. I tried my puter on a CRT monitor today... Qualty was FREAKIN amazing....
I have 3 LG Flatron W1942Ts
i changed color quality from 32bit to 16bit. MASSIVE improvment. Shouldnt it be other way around -
If you haven't already, get the latest WHQL certified drivers for your graphics card. Also, try disabling any video enhancement settings in the graphics driver applet. If that doesn't fix the problem, try different output devices in the media player software. For example, in VLC: Tools -> Preferences -> Video -> Output.
problem is my screen caps look amazing. A bit interlaced but great quality
Make sure you graphics card is set up to output at the monitor's native resolution. Also make sure the refresh rate isn't too high. Try 50 or 60 Hz, whatever your monitor accepts.
A screen cap
Thats DIGITAL BROADCAST. From my digital tv box into a canopus ADVC300.
I would be happy with the quality of the screen caps but that NOT what im seeing -
Mate, why the heck are you reencoding digital broadcasting?
It's digital already, most likely MPEG2 or MPEG4.
You can capture it directly as a stream to your computer or on the HDD of your receiver.
If you are capturing from VHS through the ADVC300 then the output is DV AVI, interlaced, PAL, bottom field first. Try deinterlacing and see if that helps.
I don't see any "pixilation" in the cap. If you are seeing something different try to take a picture with a digital camera and post.
Otherwise I am at a complete loss as to what could possibly be going wrong, if anything. -
The issue, as has been stated, seems to be the relationship between your graphics card and your monitor. If your card does not support the native resolution of your monitor, the monitor could display artifacts as it is is changing the ratio. Put that into figures then if your card only outputs 1024*768 then your monitor must be set at 1024*768 (regardless of the ratio of the source material).
Does this monitor come with drivers ?. You must not rely on native windows drivers even if they state they support your equipment.
On the 'digital' issue, I may be very wrong on this but the recording may be digital but the output from the recording device could be analogue which then needs a conversion through the ADVC -
OK. I have sorted the problem down to this. High quality rips look GREAT through VLC and Media Player. BUT when i open them in Premier Pro or Sony Vegas. They look like S%&t. They are ok when paused (only interlace flicker) and preview is set to best quality. As soon as i play, the quality drops to half and it looks like fly screen. Any ideas
How can you edit and clean up with filters if it looks like crap. You don't know what the product will look like
that was a genuine question. I am trying to enhance videos to bring out detail, color correction, remove noise etc. Do i just keep rendering samples? that gets insain as it takes time to render.
Pixelated Video
By toadzky in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2010, 03:28 -
choppy video, pixelated
By psmankikar in forum ffmpegX general discussionReplies: 3Last Post: 18th Feb 2010, 15:50 -
Video background is pixelated
By RagingSloth in forum Newbie / General discussionsReplies: 27Last Post: 23rd Apr 2008, 11:04 -
Pixelated/blockish video
By rancid in forum Authoring (DVD)Replies: 5Last Post: 27th Feb 2008, 03:01 -
Captured video is very pixelated.
By otnpabka in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:02
