Hi
I have a sony ax-2000 which records on memory sticks.
but there is a problem by recording in 1080 25 p . when I record in this mode the picture showed on lcd by some delay.(like recording on some old mobiles).and when I play my recorded movies the problem is exist.
so what is wrong?
please help me
is your computer fast enough to display it? fill out the portion of your profile about your comp.
and welcome to the forum!--
i'd be taking it back or in for serrvice, that isn't normal.
I have the same problem with sony ax2000E when i use format 1080p.
Did you solve the problem? -
no it doesn't solve. I have this problem by canon 7d and canon xl2 and ax2000e.
when I record in 1080 25p it shows frames with some delay.
but in my 7d when I record in 50p or 60p there is no problem but in 25p there is problem.(like webcam with some delay). -
The probably reason for the lag in frames on your Sony HDR-AX2000 is due to the fact that the "25" dictates the number of frames per second (fps) that the camcorder is shooting in. The higher the number, the more frames per second, therefore the more clear and smooth the picture will look. 25p (or 24p in US), as well as 30p does have some "lag" in when zooming and panning, therefore, due to the lower fps. However, in 60i my picture looks clearer and smoother when I pan and zoom. The problem with the 60i (Interlaced) is that the pixels are laced together therefore the picture will not be as detailed in post-production. But the higher frame-rate does prove for clearer picture.
I hope this helps! I just received my Sony HDR-AX2000 a little over a week ago. So I am still trying to learn it, but I have learned quite a bit already.
How to re-encode .mts 1080p (60fps) from SONY HDR-CX560V
By Umen Pich in forum Video ConversionReplies: 9Last Post: 15th Sep 2011, 00:21 -
SONY HDR-AX2000E: "only" 1080i via HDMI, not 1080p?
By flashandpan007 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jul 2011, 05:50 -
sony hdr-sr12 new HDD camcorder is 1080p or 1080i?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 31Last Post: 8th May 2010, 14:04 -
Sony's HDR-AX2000 AVCHD format
By 392 in forum EditingReplies: 4Last Post: 17th Jan 2010, 21:40 -
Problem installing Sony HDR-SR1 on XP.SP2
By erik010 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 1st Jul 2007, 07:40
