Results 1 to 9 of 9
  1. Good evening everyone.
    I am completely new to this and am absolutely stuck, I am hoping someone can help me as I am not very good with all the technical jargon and have been trying to do this all day.
    I had an AVI file containing a movie - using avi2dvd I created the following files in a folder named VIDEO_TS
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VTS_01_0.BUP
    VTS_01_0.IFO
    VTS_01_1.VOB
    VTS_01_2.VOB
    VTS_01_3.VOB
    VTS_01_4.VOB
    I then downloaded Nero (Lite) and followed the instructions. Put all the above files in and clicked burn to disc, which it then spent an hour or so doing.
    The files were written onto the disc but I won't play in any dvd player in the house, nor on the PC.
    Am I doing something wrong??? Surely it can't be this difficult
    Thanks in advance
  2. The root of all evil träskmannen's Avatar
    May 2005
    Belgium
    It looks like Nero is playing tricks on you - most likely you didn't use the right setting. I would use ImgBurn instead. Choose "write files / folders to disc" from the start-up screen and drag-and-drop the VIDEO_TS-folder to the ImgBurn window and start burning.
    In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
  3. Member bendixG15's Avatar
    Aug 2004
    second the motion .....
  4. Hi there, thanks for your message
    Ok I downlaoded the package you recommended.
    Not sure if it has changed slightly since but I clicked on Video DVD on the options at the top
    Then I clicked ''add files'' and imported the files from the VIDEO_TS folder (only only the 4 VOB files appeared - the BUP and IFO files were not selectable)
    Then i clicked ''burn Video DVD'' and it's currently processing. (1hr 46 to go)
    I am assuming / hoping I have done this right and see what happens
    Thanks again
    Dec 2005
    Canada
    What you say doesn't sound like this:
  6. No it didnt look like that at all.
    I clicked on the link provided by Taskmannen and downloaded it.
    Top of the program says ''Express Burn Disc Burning Software''
    In any case it worked. Threw it in the dvd player and all was well for 7 minutes. Then I lost the sound, it came back on 10 minutes later but out of sync by minutes.
    Surely this is not that difficult, don't think I'm cut out for it.
  7. Originally Posted by Scallywag1980 View Post
    You click and download 'Express Burn Disc Burning Software'' from ad banner in ImgBurn site
    and you not first one
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just think....had you bought the DVD you'd be watching it right now...
  9. Member classfour's Avatar
    The Heartland, United States
    Click on the "imgburn" link to the videohelp website and select "direct download link".
    Or use this:
    http://www.imgburn.com/index.php?act=download
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
