I recently encoded some video clips in various formats that are on my computer, hoping to be able to play them on my DVD player. I used a program called DVD Flick and then burned a DVD using Image burn. The resuting DVD will play on my computer,but not on my Magnavox2160MW9A player recorder nor on my Panasonic DMR EZ48V. It will however play on a borrowed Coby 288 DVD player (which has no recorder nor TV tuner). I don't understand why this should be. Is there anything I can do to allow the DVD To play on either the Magnavox or the Panasonic or both?
Results 1 to 10 of 10
Are they +R's or - R's ?
ALso if they are +R's is the booktype being set to DVD-ROM ?
My panny standalone recorder will only play -R's unless i change the booktype on my +R's to dvd-rom.
Which i always flash my burners firmware to do it automatically.
You would have to check them with dvdinfo or imgburn to see who actually makes Panasonic brand dvdr's but i would suspect they are probably cheap media. -
I'm using Verbatim Disk -R and have also used Panasonic -R. Windows 7 64 bit
Thanks for the reply below but I don't undestand what you mean by changing the booktype and by flashing the burner--I'm new to this--please give more details. Iv'e been using Verbatim and Panasonic -R's-- Win 7 64 bit
+/- R ?
Which i always flash my burners firmware to do it automatically. -
if you are using -r try bruning speed 4x this works on all players. and try sony -r these dvd,s work great.
Are ANY of you going to bother to ask the OP where these "video clips" came from? (IE they might be PAL....or they might be a mix of PAL and NTSC).
HELLO??!!??
Cedocida - "Jittery" playback on some media players/DVD players
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2010, 19:20 -
Burned DVD only plays in newer players
By rsherid in forum Authoring (DVD)Replies: 11Last Post: 16th Jan 2009, 04:02 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
Region 1 plays on all players???
By snadge in forum DVD RippingReplies: 6Last Post: 4th Mar 2008, 15:24 -
Format free DVD-R (plays in both PAL and NTSC DVD players)
By Disco Makberto in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2007, 00:34
