For reasons I won't take the time to list I prefer to use my AWI Radeon card to capture in DVD (720x480) format. Then I convert to VCD or DxiX or whatever. My workhorse program for these conversions has been FlasK which is fast and simple to use. I recently converted to Windows-xp with NTFS formatting so I could capture longer segments using the ATI TV-tool with file sizes in excess of 4 gig. Capturing is no problem but conversion is.
FlasK v5.94-Intel doesn't seem to want to recognize mpeg-2 files larger than 4 gig. So I need soneone to recommend programs that will convert or frame-serve mpeg-2 files larger then 4 gig? Incidently, I think my 4+gig files are not corrupted because the Window's Media File Player has no problem playing them.
hi there,
that's a unique problem.
do the mpegs load into powerdvd?
yes?
how about powerripper? That used to use powerdvd's overlay to convert.
Just a thought. -
use avisynth so solve your problems. go to my user guide @
http://forum.vcdhelp.com/viewtopic.php?t=78221
and instead of the whole v= a= audiodub stuff just put in
mpeg2source("c:\whereitis\.mpg") and follow the rest of the guide.
Converting from mts to MPEG 2 I-frame HD in an AVI container
By shaunthesheep in forum Video ConversionReplies: 68Last Post: 8th Jun 2011, 08:08 -
Can you use frame serving for video conversions?
By johnharlin in forum Video ConversionReplies: 2Last Post: 2nd Mar 2011, 23:39 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
Frame serving
By carlmart in forum Video ConversionReplies: 2Last Post: 2nd Jul 2009, 09:39 -
Vdub frame serving to CCE ?, UPDATE ..Fixed the Error
By theewizard in forum Video ConversionReplies: 15Last Post: 1st Feb 2008, 00:24
