I've some video files in MP4 format and I've tried plenty of video converters and it's not working.
I've also tried converting MP4 to AVI, MPG and DVD-Video but none works.
During the conversion process, in the results window, usually, there will be this statement along the lines of:
"SBR not implemented. Update your version of FFMpeg to the newest one from SVN."
I've tried searching for this FFMPEG thing from SVN but there's so much technical stuff and I can't even make it out.
Below are some details from MediaInfo about my MP4 video file that you guys may find helpful:
General
Complete name : C:\Sheldon\01ToolsPart1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 329 MiB
Duration : 1h 0mn
Overall bit rate : 762 Kbps
Encoded date : UTC 2008-07-16 06:46:44
Tagged date : UTC 2008-07-16 06:46:44
Video
Format : AVC
Format profile : Main@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Duration : 1h 0mn
Bit rate mode : Variable
Bit rate : 672 Kbps
Maximum bit rate : 2 742 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.073
Stream size : 290 MiB (88%)
Title : Video
Writing library : x264 core 59 r859 ce13bb6
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / brdo=1 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=1 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=0 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=672 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Tagged date : UTC 2008-07-16 06:47:00
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : No
Codec ID : 40
Duration : 1h 0mn
Bit rate : 87.7 Kbps
Maximum bit rate : 102 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 37.9 MiB (12%)
Title : English
Language : English
Encoded date : UTC 2008-07-16 06:46:58
Can someone advise me?
Thanks!
Nikar
Hi
Try using a different converter such as MediaCoder. From here:-http://www.mediacoderhq.com/
When you install it maybe it will include and up to date version of ffmpeg.
(I think that the error message is telling you that your current version of ffmpeg doesn't support the audio AAC-SBR codec that's used in the file C:\Sheldon\01ToolsPart1.mp4). -
format factory is another good program to try - freeware.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I've also had success with Format Factory. That is now my main converter.
I have had great success with convertxtodvd. This program is great converting mp4's to dvd format.
Lawrence Johnson
Problems converting MP4 to AVI
By Missmax in forum MacReplies: 3Last Post: 11th Mar 2012, 13:50 -
By Missmax in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 15:40 -
Having problems converting from MKV to Mp4
By brucexx in forum Video ConversionReplies: 2Last Post: 10th Jun 2010, 19:52 -
problems converting to mp4
By jedibri17 in forum Video ConversionReplies: 8Last Post: 28th Dec 2007, 23:20 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 21:57
